Chợ thông tin Xây dựng Việt Nam CHỢ QUẢNG CÁO - RAO VẶT Sản phẩm - Dịch vụ khác » Máy ép mẫu luyện kim tự độngMáy ép mẫu luyện kim tự động
Cũ 27-05-2013, 12:39 PM
kmibiz kmibiz đang online
Tham gia ngày: Dec 2012
Bài gửi: 4.104
Mặc định Máy ép mẫu luyện kim tự độngMáy ép mẫu luyện kim tự động
Máy ép mẫu luyện kim tự động - Automatic Mounting Press
Additional Info
AMP-2 Automatic Mounting press
AMP-2 is auto mounting press with the water-cooling technology, Mounting press is used for inlay the irregular metallurgical specimens. AMP-2 is an auto-machine, it can setup with the heating temperature, mounting time and force.the operator can choose the mounting mould among diameter: 22, 30, 45mm in one AMP-2, so the users can tailoer the mounting size base on the dimension of testing specimen, and it will save the consumables so as to save the investment obviously.
  • Power:Max.1000W
  • Pressure:0-2MPa
  • Temperature:0-300℃
  • Dimension:380×350×420mm
  • Net Weight:100Kg
  • Cooling system:By water
AMP-1 Automatic Mounting press
Mounting press is used for inlay the irregular metallurgical specimens. AMP-1 is an auto-machine, it can setup with the heating temperature, mounting time and force.
  • Order#:713-212/222/232
  • Power:Max.1000W
  • Pressure:0-2MPa
  • Net Weight:100Kg
AMP-5 Automatic Mounting Press
Mounting press is used for inlay the irregular metallurgical specimens. AMP-5 is an auto-machine, it can setup with the heating temperature, mounting time and force. Four different size of mould is available for mounting, and it can inlay two specimens simultaneously.
  • Order#:713-281
  • Power:Max.1800W
  • Pressure:0-2MPa
  • Diemension:6150×510×500mm
  • Net Weight:110Kg
NAMDUONG EQUIPMENT JSC. Sales Manager: Mr. Thao
- Mob.: 0983 113 188
- Email: thao(a)thietbinamduong.com
- Redundancy: vudaothao(a)gmail.com
Cty in ấn tại Hà Nội, chuyên in decal pp giá rẻ và in poster lấy ngay sau 10 phút. LH 0979 407 447
Múi giờ GMT +7. Hiện tại là 08:49 PM
